SWA Asst DXer schedule and pay?
So under the old contract a step one Dispatcher made $5,087 per month and the Assistant Dispatcher made 74% of that which is $3,764.38 per month. Which breaks down to $23.52/hour for a 160 hour work month. Am I reading that correctly?
Someone had mentioned earlier in the year that Assistant Dispatcher's made around $55,000 per year which would be around $4,580 per month. There seems to be a disparity. Will someone clarify if able?
That's the base pay. There are, um, other factors that make up what you'll actually get in a paycheck. The second number you've come up with is closer to accurate and it'll be even higher starting June 1st.
Slightly off topic but any of you SWA folks care to chime in or have knowledge about the ATC Mgr position? PM's are welcome as well.
