Though math is involved (especially to finesse it), this is more lateral situational awareness.Holy crap. I haven't taken a math class since highschool, and they stopped teaching mental math in 5th grade.... Deltas out for me.
only problem is the delta test choices will be like:Most of this type stuff is not math based it's more spacial orientation recognition. If you are on the ABC VOR 180 radial at 100 miles and they want you to hold on the ABC 110 radial at 40 miles, you really have to have some basic knowledge on how to get there. It's really not that hard to pick up once you've been shown it a few times. Try looking at a RMI face as if you were looking down on it, not at it. Find where your airplane is on it and then find out where you want to go. Draw an imaginary line in your mind as to what direction it will take to get there....you won't be off by more than 5 or 10 degrees. Seriously, don't make it harder than it is.
Without thinking much about it, I bet a heading of about 025 to 030 would get you pretty close. That's doing it the manual way. Fortunately the FMCs today do all the work for you but you still need to have a basic understanding of doing it the old way. It sucks, I know.
a. 022
b. 025
c. 028
d. 035
nope, pen and paper, that's it....assuming they do it the same at DL that the did at CPZ.IIRC, a calculator is allowed. Draw a triangle, hit up some simple trig and you'll be right on it.![]()
a. 022
b. 025
c. 028
d. 035
I'm right there with you. Perhaps if I'd went to college. I still wouldn't be good enough to land in Juneau though.
Go with B. My dead reckoning skills say it's a little more than 22.5 and less than 028. 025 should just about do it. I'll punch it in the FMC tomorrow and see if I'm right. Maybe we can have a 15 minute point to point seminar at NJC. Sounds fun eh?
Okay nerds.
Besides doing a bunch of trig to figure this one out, what do you think the correct answer is?
KTAS=300. Aircraft is going to teardrop outbound on the 060 radial and wants to roll inbound on the 100 radial. If the aircraft must start to turn at 20DME, what constant bank will roll you out on the 100 radial?
My Delta gouge says it would be 14 degrees.
But, according to math, the gouge is wrong. The correct answer is just shy of 10 degrees. Is there a general rule of thumb?
My estimating skills don't get it all the way through, but this is what I've got...
Basically, a turn from a point outbound on the 60* radial to a point inbound on the 100* radial is a 180* turn... kind of. The distance between radials at 60 DME is 1 mile, so the distance at 20 DME is 1/3nm. There are 40 radials between 60 and 100 so that gives you about 13 miles between the two points at 20 DME.
To find the distance you'd have to travel in the 360 degree turn with those two points you multiple 13 by pi which gives you about 40. Half of that (180 degree turn) is about 20. 20 miles at 300 knots takes 40 minutes. A standard rate turn (3*/sec) takes 1 minute to do 180 degrees so we are talking about a 1/4 standard rate turn (4 minutes instead of 1) which is .75*/sec.
To find bank angle for a given rate of turn involves solving for the tangent of bank angle and at that point I am lost.
i've found a lot of the answers on the DL gouge are wrong....Okay nerds.
Uh, with radar monitoring, "fly heading (___) and direct Volunteer when able" is perfectly legal.Serious question... If your RNAV drops out mid flight, and ATC gives you direct to some point in the sky that requires trigonometry on your part, can you even legally accept the clearance?
This seems to me like giving a /A plane direct a VOR outside the service area, legally you can't accept it right?
Ha @juxtapilot ! You asked me to solve the problem, not solve it like a Delta genius!!! LOL. Either way I'm toast if I were to take that Delta test.![]()
It is being used but only on a Delta test...Possibly me too. Can anyone verify the practical application of this mental math? I'm not opposed to learning it, but I want to know that I'll be using it realistically. I was pretty sour about having to demonstrate NDB approaches 14 years ago and I have never ever shot one in actual to this day, so I still kind of resent it.
