Roger Roger
I am le tired
Well, I mean, if I did do that I'm not sure I'd publicly proclaim that I was running tanks dry on 135 legs.naaaa... just wait for it to sputter THEN its time to switch
Nah, they're not dry until the engine actually quits. That was just a hicup.Well, I mean, if I did do that I'm not sure I'd publicly proclaim that I was running tanks dry on 135 legs.
Also if you're in the -350, you have the fuel pressure lights or whatever they're called up on the glareshield. When one of those flickers you usually have like 2-3 seconds before it sputters, so THAT is when you switch them.
Besides, they don'e burn even enough to have them both do it at the same time, which means you still have another engine. And that's all I ask for every flight - 1 of the 2 engines to keep running and the lifting/control surfaces to stay on. Everything beyond that, I can handle.
I had a run that was over 5 hours every night. Then another that was over 4. I had to get gas every night, and I would almost always wait for the light. I wanted to know that tank was in fact empty and no longer usable. If fuel started to get close because of missed approaches, I didn't want to be going back to a tank for 10 mins, then back to the mains again while on an approach or whatever.AMF experience? When I was out of OAK, we only had one run that would occasionally necessitate picking up extra gas at one of the stops. I think I ran 2 tanks dry while I was there. You're right- fuel pressure hiccup then engine hiccup. Not a big deal, though I never did it on purpose.
The Coochmonster used to get so mad when I would get 6 gal a side in RDD lol.
out of curiosity, what kind of power settings/fuel flows did you run on the -350s?Yep. Nothing like having to justify the fuel burn that COMPANY SOPs REQUIRED US TO USE. God, that man is miserable.
Those Whiplines are a deal breaker.oops! lets try again.
