I was commuting home from ORD to BNA one evening on the jungle jet. We were heavy, fully loaded in the LR. A UA 777 took off in front of us. I was thinking "Eh, we'll be using a lot of that runway so the captain will probably wait it out" nope, he went right at it so I held on a little tighter then usual. After a long takeoff roll we lifted off and at about 500 ft, we did a quick, very hard left. The whole cabin gasped and one woman actually screamed.
AFAIK, a heavy wake turbulence delay can't be waived. They must have waited the 2 minutes unless someone screwed up.
How do they intend on getting around the runway spacing requirements, or is this more for succeeding departures?
Do some google-fu and you'll find the actual published RECAT minimums.
Personally, I'm curious to see what the result of this would be when it involves someone other than the home of FedEx. Not a knock against FedEx, but they are predominately wake aircraft flown by freight guys/gals![]()
Having the ailerons all the way to the stop and still not getting what you want is interesting.Ahhh nothing like trying to turn left, but the aircraft is still rolling right.![]()
The vortex is narrow, and if you are really in it, it exceeds your max roll capability. Elevators are your friend!
I can't tell if this is sarcasm or not?
Seriously, you think climbing out of a 100+ degree roll event is a valid escape maneuver?
Well uhh, if you're rolled 100+ degrees I doubt the elevators will do much climbing.![]()
Not a "climb", just the fastest way to exit the vortex. You need to pop out of it before roll control will help. I have done it quite a few times over the years, and it works well. Just 15' moving in the direction of the vertical axis is all you need. Think of it as the equivalent of what you do if you encounter a riptide. Do you swim against it (aileron only) or do you to swim laterally to the shore (elevator control) to exit the current?
Mine's bigger!
(errr, wait...no, it isn't...but we're far more fun.)
Elevator doesn't stop the momentum of the roll, it just gets rid of the elephants. Ailerons can stop the roll once out of the vortex, but can't compete if you stay in it. The sooner you add a little back pressure when encountering the roll event the sooner you'll have control back.I understand the premise, but, at least in the 50,000lbs airplane I fly, during an event that is not correctable with full aileron input, I somehow don't see the elevator being of much use either in stopping the momentum of the roll. It's kind of like a whole bunch of elephants just jumped out of the plane in front of you and landed on your wing. It doesn't matter if you climb out of the stream of jumping elephants. You are rolling down until inertia (well, lift) can counteract the weight of the elephants.
I'm honestly embarrassed to admit that I've never thought of this or was taught this as a technique to escape wake turbulence. I'm usually A's and E's and then wondering if I packed an extra pair of skivvies.Elevator doesn't stop the momentum of the roll, it just gets rid of the elephants. Ailerons can stop the roll once out of the vortex, but can't compete if you stay in it. The sooner you add a little back pressure when encountering the roll event the sooner you'll have control back.
