ZapBrannigan
If it ain’t a Boeing, I’m not going. No choice.
I think what people are missing is that in normal flight conditions most airplanes are easy enough to fly. Where the early Lears (and other swept wing airplanes) tend to bite you is when you inadvertently venture too close to the edges and THEN exercise inattention or poor technique. There would not be any upset recovery training if pilots never inadvertently found themselves in an upset condition. One highly regarded provider in Mesa, Arizona frequently cites the example of cheating the base to final turn with rudder. An inexperienced pilot who ends up slow and cross controlled, might find themselves in an upset without the altitude to recover (if recovery is even possible). The early Lears would have exacerbated the problem with spoileron deflection. I don't think these machines are particularly difficult to fly, but they're certainly not going to have Cessna 172 stall characteristics. You'll be way behind the power curve, with a slow spool time, little roll control, and an elevator which "may" be partially in the shadow of the fuselage. I'm no aerodynamicist (clearly) but I respect the airplane.
It's not the most unforgiving airplane I've ever flown (That honor goes to the Jetstream) but it is a slick machine that can easily get away from you if you are inattentive.
