I like it when dispatch plans us to get to the alternate with 3000 lbs of gas. Seen it!
Oh wait, this thread is for awesome dispatchers complaining about idiot pilots. Carry on.![]()
Recently, in Brasilia ground school:Feel free to start a thread about idiot dispatchers in one of the pilot forums, if you're so inclined.
There are cases where we are required to carry an alternate on international flights where the weather doesn't really require one. So, if you're already weight restricted you might put on the closest legal alternate and minimal hold fuel, to try and get all the revenue passengers on board, and the fuel over alternate might look pretty low - until you consider the fact that the alternate is only required because of the type of flight you are flying. A 737-800 flying from EWR to BOG is a good example of this; Columbia requires all flights to have an alternate listed.
Well depending on the type of aircraft and the weight, that could be ridiculously low or ridiculously high.
Thanks for the props but actually this flight was from, say, Cherry Point, NC to a military airport in SoCal (maybe RIV).USA3000 must be tough for transatlantic. It was tough enough dealing with some of that for a large ETOPS widebody. Kudos to you!
Remember what I said about not flying the airlines only airplaneYou must have some drama queen pilots or bad dispatchers because I'd say MAYBE one flight out of 20 do we have to contact our dispatchers for anything. And our trips are usually logistical nightmares.
Not kidding, I would LOVE to read a thread with pilots' thoughts and challenges from dispatchers. Woudl be great learning for us, and also give us a chance to explain some more of our job to you.
Similarly, instead of you explaining to and educating us on what we say, you come off somewhat defensive and argumentative and are sizing your own shoes to be in that 5% category.
I had one of my busiest shifts during the crazy weather going on last night. Dealt with many pilots on many different topics and al of them were great. I really felt the teamwork.
300,000 lb. 767-300ER. About 15 minutes until you turn into a glider.![]()
DasLeben doesnt like dispatchers. He would rather pilots plan their own flights.
I'm trying to understand what is wrong with 3,000 alternate fuel. Can anyone explain?
How do you type on that FMS with boxing gloves on?International supplemental fuel requirement. Destination, then to furthest alternate, plus 10% of total flight time (unless B043, then only 10% Class II), plus 30 minutes holding at 1500'. 3000 lbs in a 767-300ER is about 15 minutes of fuel until flameout.
I have a lot of experience with the 767-200/300 and I find it hard to believe it was planned at 3000 lbs. The reserves (FAR RSV) alone would be around 5,000 lbs minimum if the flight plan was flown correctly. Now I do believe that you can work the numbers to show 3000 lbs by saying the FAR RSV (30 min) is taken into account BEFORE the diversion if you had extra (XTRA) added to the fuel plan. However, that is not its purpose.
I just did a 767-200 International/Supplemental Flight Plan (ZZZZ - KMIA); below is the fuel burn data. I added an extra 10 minutes over the minimum reserves too.
--------------------FUEL----------ENDUR
BURNOUT.......28693..............02:46
10 PCT.............2603...............00:17
ALTN KFLL......1971................00:11
FAR RSV.........4506................00:30
REQD............37773................03:44
XTRA .............1527.................00:10
TAXI.................600..................00:10
CLEARED.....39900................04:04
Fuel At Touchdown in KMIA: 10600
Daslenen,
Like was said above, sometimes, as you're probably well aware, the alternate is just there for "sh*ts and giggles" simply because it is required by the regs (e.g. 121 supplemental). Even if its clear and a billion. KFLL is the perfect alternate for KMIA in this case even if the reserve fuel is on the lower end. It isn't practical to use KMCO, KTPA, or KJAX when its just a paperwork alternate.
