Autothrust Blue
Welcome aboard the Washington State Ferries
It's an MD-95, not a B717.
And if someone says "Boeing MD-11", meet me out in Lot D...
However, what I don't know is what happens in a Boeing if authrottles are off and you are handflying and then carelessly the speed bleeds and you go near stall speeds.
And if someone says "Boeing MD-11", meet me out in Lot D...![]()
seagull, my opinions on AB flight control philosophy are based upon the things told to me by guys who have flown both Airbus and Boeings. While it's true that some of them like the Airbus better, I've found that to be pretty rare. They usually praise the "comfort" factor, but dislike the control philosophy. YMMV.
Like the Boeing F-15 Eagle? Or Boeing F-4 Phantom?![]()
Meh. I still can't bring myself to call that airplane a Boeing. One look at it and the thing screams Mickey Dee's.Actually, no, it's not. The serial number plate shows "B717-200." There's no such thing as an MD-95.
As distasteful as the advert may be, the above statement is utter nonesense and belies a lack of knowledge of what is happening in current design.
What ExcelAire? Wasn't that the Brazil midair with the GOL? An Embraer Legacy jet....unless the AOA inputs to the FAC are wrong, you know...like what happened to ExcelAire. Then you can pull, pull, pull straight into the ground.
From a human interface point of view, it's that other 1e-12% that is really worrying, because suddenly "max alpha" inputs won't give you max alpha inputs anymore. Ahem.
Sent from Seat 3D
Again, how? What specifically?
I![]()
***I would sure love to see Lockheed come back into the commercial aviation market.***
And again, go back and read A Life Aloft's excellent post. He explained it beautifully.
Also on the 777, when one control yoke is moved by a crew member, the other yoke moves as well. If the autopilot is flying the plane, both yokes will reflect the autopilot's control inputs. Even if the flight crew is busy with charts or messing with the radios, the movement of the yokes in front of them will provide a continuous visual indication of what the autopilot is doing. If the captain is flying manually and the first officer suddenly has to take over or become involved in the control of the airplane, he probably will already have a sense of what's going on control-wise from the movements the yoke has been making in front of him. It's an awareness thing, and can be a critical factor in an emergency situation.
Side sticks do not provide this level of crew awareness. The movement of one stick does not move the other one, hence the non-flying crew member will not be aware of the other person's, or the autopilot's, control inputs other than by instrument indications and by what the airplane is actually doing. Even if the side sticks did move together, their location puts them outside the "awareness bubble" of a non-flying crew member if he's involved with instruments or controls in the center of the panel or on the aisle stand.
The Airbus does not have autothrottles., that's why the throttles don't move. It has autothrust. I don't need to see the power levers to know what the airplane is doing. That information is on column one of the PFD FMA and on the EWD page. And like any other airplane, you can turn the autothrust off and do it all manually.And, the Boeing philosophy extends to the throttles. When the engines on a Boeing plane are being controlled by the auto-throttle, the power levers on the aisle stand move to reflect the action of the auto-throttle. The auto-throttle on an Airbus does not move the power levers. They simply remain in the last place they were positioned before the auto-throttle took over. It's that awareness thing again. If the flight control computers determine a power application is needed during some phase of the flight, Boeing pilots will see their power levers move up the quadrant. The only indication Airbus pilots will have is the acceleration of the airplane, possibly the sound of the engines spooling up, and the readings of the engine instruments. In a high-stress, high distraction environment, on final in severe turbulence, for example,these are all things that could be overlooked for several critical moments. That's not to say it's impossible for Boeing pilots to overlook the action of an auto-throttle, but at least they've got some big levers moving under their noses to indicate what's going on.
