ppragman
No pasa nada.
Then why are you so keen to avoid them, if they're so easy? Yes, they teach more scan and crosscheck and do build those basic instrument skills, as well as hone them. Especially for pilots who haven't flown alot of them to where they're second nature. Not everyone has that exposure that you did.
I'm not keen to avoid them, and used to fly them for "fun" single pilot in the 1900 (GASP EGADS!!!) in the Dakotas when I was bored in the middle of the night. Generally, though, there is a better approach to use, and with passengers on board, I don't think anyone would appreciate it if I had to go missed and change approaches because I used the NDB approach that gets me down to 900' AGL, when I could have used the RNAV to go down to 700' and seen it right away. That said, if it's the "best" approach to use, because of weather, or because of the direction I'm coming from, I'm not averse to using one, they're simple.
You mean, "I don't particularly see any reason why I shouldn't do things the laziest way if I could". How about fly the NDB primary, with the GPS as the backup? Or is that too much work now that you've left the real flying behind you in your current employment?![]()
Not necessarily the "laziest," rather the system is "more accurate." If given the choice, I'll use the most accurate, or most efficient system available to me. I'm not going to fly an NDB with a procedure turn that takes extra time if I can "Descend via the TAA" for the straight-in LPV approach. Conversely, if the direction I'm coming from favors an NDB, or some other approach and the weather is good enough so that I can be sure to make it in, but not good enough to cancel and come in VFR, what approach do you think I'm going to fly? The NDB every time.
A similar example happened just the other day (though with a VOR approach), I was heading into PAMC and the weather was a little low, not bad, but I wouldn't be able to cancel and come in VFR. I didn't want to trek out to KICEB, which would have been the most convenient IAF for a "better" approach (the LOC/DME 16) other than a procedure turn (which also would have eaten up extra time), and I was already direct to ERLAN because of my routing, so I flew the VOR/DME-C instead of the other approach because it was more "efficient." I broke out well above mins, and flew the circle to land and landed without incident. The point being, I'm not averse to stepping down to a lower "level" of approach if the conditions suit it, but if I have the ability to fly a better equipment.
http://www.airnav.com/depart?http://155.178.201.160/d-tpp/1212/01225VDC.PDF
I don't know the point of increasing my workload if I don't have to. While the airplane I'm flying is "simple," if I screw up and fly into a mountain, I'm just as dead as if it was one of the more complicated ships out there- so I try to make my life as simple as possible while still maintaining my proficiency. I fly plenty of "hardcore IFR" (whatever the hell that means) into icy runways - truth be told though, I'm in the business of risk mitigation, so I'm going to make things as easy as possible for myself so I don't have to pull my ass out of a sling, that means taking simple steps like flying the overlay instead of the raw NDB, limiting myself when the flying conditions deteriorate, and operating as conservatively as possible while still being able to complete the flight and do my job.
