You have to get a letter of agreement. I forget specifically but I think you submit five different radiotelephony call sign candidates and five different three-letter identifier pairs, and then the FAA/powers that are decide which one you get. I'd call the local FSDO. If they don't control the process they'll know who does.Anyone know how to create a call sign and register it with ATC (ie Skywest 456 instead of N12345)?
Im looking to do this at our company.
Also is there any limitations on this? like where we can or can not use this?
No.Is it me or did this thread end up in the "pictures from the road" section ?
Don't EVER use one without being awarded it with the LOA process. Don't just make up your own and file flight plans with it. Please. Thank you.
actually we'll probably just say "What's the callsign?" and go with whatever you say.
It's still around but since they reinstated the ability to block it's probably not used as much.
I'm sure your local FSDO can assist you with the process.
I'd assume it just has to go through some sort of approval with the FAA to authorize it. We get briefing sheets quite frequently with new ones that are put in the system.
As far as what you can use, as long as it is not close to one already used - I've seen some pretty funny names out there.
Correct me if you disagree but I am pretty sure somebody who had some balls could make something random up and we would never know XTC123 or "Ecstasy 123" wasn't a legit callsign. Or does FSS have some way of verifying legit ID's?
