From the Federal Register:
Advisory Circular for Stall and Stick Pusher Training
AGENCY: Federal Aviation Administration (FAA), Department of Transportation (DOT).
ACTION: Notice of availability of proposed Advisory Circular for Stall and Stick Pusher Training, request for comment.
SUMMARY: This notice announces the availability of a proposed Advisory Circular, regarding stall and stick pusher training for transport category airplanes for comment. This Advisory
Circular provides guidance to training providers on stall event and stick pusher demonstration training, including recommendations and best practices for academic training, job performance training, and instructor training.
Background
The primary goal of this proposed advisory circular is to provide training, testing, and checking recommendations designed to maximize the likelihood that pilots will respond correctly and
consistently to unexpected stall warnings, aerodynamic stalls, and/or stick pusher activations. Additionally, the advisory circular provides guidance for operators and training centers in the
development of stall and stick pusher event training to include stall prevention, recognition of an approachto-stall or actual stall, familiarity with stick pusher systems, and the correct procedure to recover from those conditions. Core principals of this Advisory Circular include:
• Emphasis of ‘‘reduce angle of attack’’ response as the primary response for stall events.
• Clarification of the evaluation criteria for a recovery from a stall or approach.
• Scenario-based training that includes realistic events that could be encountered in operational conditions, including stalls encountered with the autopilot engaged.
• Clarification of training to a full stall, to ensure that pilots execute the stall recovery at the first indication of a stall.
• Stick Pusher demonstration training.
The information within this proposed advisory circular was developed based on a review of recommended practices developed by major aircraft manufacturers, labor organizations, air
carriers, training organizations, simulator manufacturers, and industry representative organizations. The FAA recognizes that the content of this draft AC explains in further detail concepts proposed in the supplemental notice of proposed rulemaking (SNPRM), entitled
Qualification, Service, and Use of Crewmembers and Aircraft Dispatchers, FAA Docket FAA–2008–0677, and corresponding flightcrew member training AC, regarding stall and stick pusher training. Following review of the comments regarding the stall and stick pusher training proposed in the SNPRM, this advisory circular may require additional revision. The FAA will review both the comments received in response to this advisory circular and the SNPRM, and revise the documents
accordingly to ensure consistency and standardization.
The agency will consider all comments received by January 12, 2012. Comments received after that date may be considered if consideration will not delay agency action on the review. A copy of the advisory circular is available for review in the assigned docket for the advisory circular at http://www.regulations.gov.
