Ayork62493
GBR
Anyone here make it through one of them? Just curious, I know they're rare but they scare the (Stuff) outa me.
Brilliant! Couldn't have said it better.
Guess I don't understand the picture, just saw somthing in a magazine saying that once you're in a bad microburst there aren't really many options.
Edit: Oh.... Crap. I god your picture now, It's late my friend. A microburt... How could it get any worse.
If you're around water or tall grass, you can see them impact the ground if you're low enough. Last year while around PAWG, we hit a pretty hefty one in the 150...Everything not strapped down went flying everywhere, including our fire extinguisher which was held down via bungee cords..that bad boy shot up and broke the rear window. I shot up and hit my head somewhat hard against the ceiling. Let's just say we called it a day after that.
EDIT: Oh and to answer your question..If you're in a small enough aircraft there isn't anything you can do if you hit a reputable one, you're pretty much temporarily out of control. The best thing to do, in my opinion, is to just avoid flying if they're in the area.
You might only have one option, but its also the only one you need.
Wings level, minimize altitude loss without stalling until you fly out of the microburst or into the ground.
I disagree. Nose down to gain airspeed to 1) minimize the time in the downdraft, and 2) have enough airspeed to survive the tailwind sheer on the other side. Anything less than Vy just doesn't make sense, and you'll probably want 10-20kts more. If you end up too close to the ground, you'll want the extra airspeed (energy) to arrest the descent the best you can. I'm thinking piston singles/light twins - not sure what makes sense for the big guys.
Those sonic Anemometers are old news already...
Your procedure will get you killed in a transport category aircraft. For a microburst, we firewall the throttles, pitch up to the command bars, wings level, don't change the configuration, and hang on for the ride. If ground contact is imminent, pitch up to stick shaker and pray.
Casey got it right.
If you were referring to what I wrote, the system I refer to is on our aircraft and utilizes a very high frequency microwave to actually detect dust particles and display locations of doppler shift on the radar unit.
On the recovery, the windshear guidance system aims for a positive 1 degree path, and will accept any extra airspeed it gets to minimize time in the event. If it is unable to hold 1 degree, it will command the pitch to increase up to the edge of stick shaker. The autopilot does a great job flying it, incidentally.
