The same reason we say "SE of the field" instead of SSE or 119.8 degrees.Why do GA pilots Insist on adding "about" when they give their distance?
Oftentimes at OAK the controller identifies me as, eg., 6.83 miles SSE of the field. I think it's comical to get it down to the hundredths (0.01nm = 60') and I'm sure it's intended that way.
You need to read the posts higher up in the thread. I didn't suggest reporting distances in tenths. I was responding to someone who suggested that the reason pilots do that is because they don't have an FMS that reads distances to the tenth of a mile.The same reason we say "SE of the field" instead of SSE or 119.8 degrees.
It is a general direction/heading, not targeting coordinates.
Sometimes the freq is busy and frankly it is considered poor airmanship to state distance to the decimal point. One aircraft may be giving you slant range DME and the other straight line GPS...Neither one may correspond with your range scale.
Even if we did, by the time we say it and you respond, we are no longer in that place....Hence we are approx/about that distance.
Why does ATC give alt changes in 1000' increments to planes climbing at 5000+ fpm?
The question is what value does saying "about" add to the transmission. That is the question nobody has yet addressed. If it adds value, then let's send a recommendation to the folks who write the AIM and get them to add that to the book since they are missing that in their section on communications. Perhaps the pilots who say "about" are concerned that if they say "7 miles north" that the controller will not be able to correlate the fact that the blip that is 6.5 miles north with no other blips around for miles is actually the aircraft to which they are communicating.
It doesn't take anything away from my transmission because I don't use it. What it does do when used is needlessly add length to a message, just like starting transmissions with "and" or putting the words "this is" in front of a call sign, or many other imprecise colloquialisms.What does it take away from your transmission?
Yes, really.Length? Really?
No, just correct. The folks who think they are "cool" are the ones with the self styled but incorrect transmissions.You're so cool.
Then why don't you and your favorite captain sit down and write a recommendation to the folks who publish the AIM. Tell them how the extra meaningless verbiage is more accurate, and drop me a line when they agree.I say good day, good morning, appreciate y'all...take it easy and all kind of other stuff that only makes for a more relaxed and comfortable work environment.
When I make a call and say I'm about, approximately or just passin' or approaching 10 miles SE of KXYZ, that is actually making my report more accurate.
As one of my favorite captains said, If you're not having fun, you're not doing it right!:beer:
See, here all this time I thought I was just being a nice guy by saying "good morning" to the controller. For shame. Even worse, he/she often says it back. FIRE THEM ALL! :laff:
Yes, really.
Yes, really.
