gne in prog Well-Known Member Apr 22, 2010 #82 ATC RET 2003 said: Urep Amil Click to expand... is that your answer to mine?
ASpilot2be Qbicle seat warmer Apr 22, 2010 #83 ATC RET 2003 said: Here's one of mine: And here's a hint: Click to expand... Dunedin New Zealand?
ATC RET 2003 No More Vectors Apr 23, 2010 #84 gne in prog said: is that your answer to mine? Click to expand... Well... in a roundabout sorta way... yes.
ATC RET 2003 No More Vectors Apr 23, 2010 #85 ASpilot2be said: Dunedin New Zealand? Click to expand... You're getting warmer.
ASpilot2be Qbicle seat warmer Apr 23, 2010 #86 ATC RET 2003 said: You're getting warmer. Click to expand... Palmerston North, or maybe Hamilton? None of the airports on A.net with ANZ 737s seems to match your picture.
TXTBOOK Well-Known Member Apr 23, 2010 #92 Hint: Check gear down. Attachments Aerial.jpg 524.2 KB · Views: 151
ATC RET 2003 No More Vectors Apr 23, 2010 #93 gne in prog said: nadi. Click to expand... Other side of the ditch.
mikecweb Well-Known Member Apr 23, 2010 #95 TXTBOOK said: Hint: Check gear down. Click to expand... edit: nevermind. See the mountains
ATC RET 2003 No More Vectors Apr 23, 2010 #99 FlyingSig said: OK, My turn: Click to expand... Disregard the hints... This one is named for DBG
FlyingSig Well-Known Member Apr 23, 2010 #100 The man is good.... both correct (well, all 3 correct) ...
