Well considering that weird argument has made it into two threads here...Somebody's been reading the absolutely ridiculous circular logic based discussions that take place at the Red Board. I'll be interested to see how it turns out here.
What may have set it off in part is that recent FAA Chief Counsel opinion that a student pilot needs a HP/complex/tail wheel endorsement even though the solo endorsement is make/model specific. If an endorsement to fly solo in a Cessna 210 doesn't imply HP and complex, why should a type rating?
(btw, I'm not taking sides in that one - I have an opinion, but it's not worth much)
An example is one mentioned earlier- the DC-3. You need a type rating to operate. I think most would agree that you most definitely also need the 61.31(i) endorsement (tail wheel)... so why would you not need the 61.31(f) HP endorsement?
61.31 said:...no person may act as pilot in command of a high-performance airplane (an airplane with an engine of more than 200 horsepower)...
I assume you're talking jets?
Seems pretty clear to me. Jets aren't rated in horsepower, so the reg doesn't apply.
Now, if we're talking a King Air 350 or a Metro or something, then yeah, you'd need the endorsement.
Source?
-mini
A type trumps an endorsement. For example, I have four type ratings for various jet airliners. I do not have a high altitude endorsement.
So just because ya'll are typed in an RVSM approved aircraft you don't need the RVSM training? I guess the easiest way to solve this issue is to call up the FSDO.
I realized that, it was just to make a point as to why just because you have a type doesn't mean you need the high altitude endorsement. I'm sure 99.9% of the inspectors out there are going to wonder if you have the type on the aircraft and not the high alt.No, the PIC must have RVSM training to operate an RVSM equipped aircraft in RVSM airpace. The aircraft must also have an RVSM LOA and is subject to numerous recurring inspections.
Furthermore, the RVSM LOA does NOT transfer with the sale of an aircraft. The new operator must submit a new RVSM application.
Unless you can find an FAA rule or interpretation that says something along the lines of "the holder of a type rating in a high performance airplane need not have a high-performance endorsement to act as PIC of said airplane", then yes.So I've been illegal for the last 4 years flying as PIC (acting and logging) of a 1900D without a HP endorsement?
That, I do not know.So, when and if I get a go at becoming PIC on a CRJ, do I require that HP endorsement? Or is a CRJ not considered "High Performance" due to the "200 HP" stipulation...
