Clearance through class B
It depends on a few factors IMO.
- How much traffic is going into or out of the Class B airport. If its time for a push or a mass arrival, good luck.
- What way are they landing/taking off?
- How professional you sound on the radio. If you call up and sound like you might be a problem, they might worry that you cant handle the instruction given, and may just decide not to work with you.
I would suggest calling the sector working the area and ask about the slow times / peak times and when its easier for you to maneuver around and through the class B.
I couldn't even get through ATL's class B IFR climbing to 10 thousand, but I've been into ORD and landed there VFR so it depends on the controller and their workload.
I've been into MEM in a 172 and landed there with no problems. We did call ahead of time to make sure we didn't show up during a push.
Tampa has a VFR corridor that goes over the top of the E/W runway at TPA. During my primary training I flew from Red Bird south of Dallas to Addison, going overtop KDAL. Granted, that was a few years ago.
I guess it really depends on which class B it is. I fly out of SLC international and we rarely get radar vectors. We have to transition routes (I-80 and Barn) that they typiclly use.
I believe, If you're not familiar with the area you could always ask for vectors (depending on their work load of course)
Flying out of KBED, I've usually have had no problem getting the Bravo clearance. As said before it depends on the controller's workload and your radio skills
In the Kansas City Class B, it's a joke, as the Class B should really be a Class C. Denver Class B is busy, but tolerable. Chicago is the same way. NY Class B can be interesting at times, Dallas isn't so bad, and ATL was def no fun.
The slower you are the less likely they are to want to deal with you. It's a huge difference to a Class B controller if you're doing 170 KTS in a Baron or 110 KTS in a 172. Conversely, the more professional you sound on the radio the more likely they are to want to deal with you. If you can schedule your flight around a non busy area and be professional, you should be ok.
How hard is it for a VFR private pilot to get clearance through the class B? I heard from some people that they usually vector you around it. I plan on doing this flight sometime in the future and I wanted to know if they'd make me go all the way around it or whatever.
Answer is, it depends which Class B and what part of the day you're trying to do it.
Houston approach seems to have a blanket policy of not coordinating VFR handoffs to/from center. I found the trick to get the handoff and a clearance through the Bravo was to wait until center let me know the handoff was rejected and my flight following would be terminated. I'd then let him know i would be climbing to 500 feet over the bravo and where I would be overflying (which usually would interfere with either arrivals or departures out of IAH). He would usually go offline at that point and then let me know approach decided to take the handoff and i'd get a clearance through the bravo.
With some tracons you just have to remind them that it might be less work for them to work with you rather than against you :)
I fly VFR in and through Bravo all over the country on a very regular basis. The biggest key seems to be professionalism on the radio. If you sound professional on the initial call up and give them the impression you know what you're doing and that you won't be a problem, chances are good they'll work with you.
I was in the Boston Bravo a few weeks ago and they were very helpful and pretty much let us go where ever we needed as long as it wasn't interfering with their traffic going in and out of Logan. As mentioned earlier, for a better chance of getting what you want, call ahead and let them know your coming.
Boston Tracon 603-594-5512.
So what do you mean by professionalism. Like "Boston approach, skyhawk 20454 just off beverly climbing through xxxx for xxxx looking for transition through the bravo"?
That should suffice. Don't call up sounding like a weekend warrior. Who you are, where you are, what you are, what do you want. Clear, concise and crisp. Nail that on the first call and I bet you get what you want. ;)
I have flown through my fair share of Class B and was only refused once - I think I was with E_Dawg and we were climbing out of LGB headed to Big Bear and thought we might as well ask for clearned through Class B as it would make our work load significantly easier. They refused so we had to work hard - looking back they likely thought we were going to split aircraft as we climed over Ontario (I got no problems with that), I think we would have been way above them by then.
As far as speaking on the radio - it really isn't what you say it is how you say it. If in your voice you project a confidence that basically ensures the controllers that you are able to comply with instructions, understand and are not overtasked by busy airspace you will be set.
I flew a number of Cessna 172s into LAX (for no good reason at all) and to be honest Class B is actually pretty easy to fly in. Everyone in there knows what they are doing, the controllers are pretty good and have it undercontrol so if you can fly the plane properly you will be fine - yeah they talk a little faster on the radio, but I took another pilot along to handle that (everyone else has 2 pilots.....).
But I would just request it..........
It is entirely dependent on what BOS is running. If they are running the 4's you may have to go around to the west. Go ahead and try to get a squawk from Beverly on the ground and see if they can coordinate it for you. From BVY going south it's not long until you hit the 2000 foot shelf of the B, so be ready.
More sackriding of San Diego's controllers:
Tonight I was out shooting approaches with a student and it was during heavy arrival time, an aircraft is handed off to SoCal 124.35 (ie. busy controller frequency, all arrivals to Lindberg, Brown, Gillespie and Montgomery on this one freq) it's a VFR on flight following. he was just handed off and checked in, Socal's response? "Cleared into San Diego's Class Bravo, own navigation to Montgomery and altitude Pilot's discretion." I even commented to my student, "damn they should have gift wrapped that one." but that's the standard it seems. Whenever I'm doing xc with student pilots handed off to SoCal from LA Center = immediate clearance.
Add altitude, direction of flight, and runway configuration and use and, aside from periodic controller attitude issues, I think you've got all the factors.
Also if you are waiting for a break in transmissions while its busy in order to get your request in there DON'T come in with a paragraph explaining every detail of your request. 50% of the time your transmission will be blocked and the other half of the time you'll make the controller miss 2 instructions he needs to issue and that will piss him off. Just keep it short and sweet until they ask for an explanation of your request. I.E. "Boston Approach Skyhawk 20454, Bravo Request" will tell the controller everything he needs to know initially and minimize the frequency congestion. He'll need to Radar identify you so he'll know where you are then. Stuttering and stammering through an initial call-up with 100 bits of useless info is the quickest way to to get "Remain Outside of Class Bravo" as a response.
+1
