Hold on, I just looked it up yesterday. All FAA freqs transmitting winds are supposed magnetic, unless noted otherwise. Though I was reading NOAAs documentation for ASOS which said it reports true.
EDIT: Just looked it up again. ASOS reports both magnetic and true winds. True winds are reported on METARS/FSS/NWS, magnetic by telephone and ground to air.
From the ASOS book:
WIND DIRECTION AND SPEED: Direction in tens of degrees from true north (first three digits);
next two digits: speed in whole knots; as needed Gusts (character) followed by maximum observed
speed; always followed by KT to indicate knots; 00000KT for calm. A Variable wind group is
reported when the direction varies by 60ø or more when the average wind speed is greather than 6
knots; or if the wind speed is less than or equal to 6 knots.
Example: 21016G24KT 180V240=Winds are from 210 degrees at 16 knots with gusts to 24 knots.
The wind direction varies from 180 to 240 degrees. If winds less than or equal to 6 knots; VRB05KT,
etc., without the degrees of variance.
And 8 pages later:
VOICE MESSAGES
ASOS computer-generated voice message are made available through telephone dial-in access and
are broadcast directly to pilots via ground-to-air radio (where installed). The information contained
in the ground-to-air radio broadcast message and the telephone dial-in message are identical. The
voice message is composed of the body of the ASOS observation and selected remarks. Selected
remarks can include variable visibility, tower visibility, or Density Altitude when 1,000 or more feet
above airport elevation. Control tower personnel may add Notice to Airmen (NOTAM) or other
information. Note that wind direction in the voice message is given in degrees magnetic.
