Low level aerobatics should be demonstrated to all Pvt. students. It is something that kills people every year and if you're teaching someone to fly this is one aspect that needs to be covered. Not doing so it gross negligence.
Engine failures due to fuel exhaustion should be demonstrated to all Pvt. students. It is something that kills people every year and if you're teaching someone to fly this is one aspect that needs to be covered. Not doing so it gross negligence
Etc., etc.
For the record, I teach many student pilots spins and believe they are a beneficial part of training. However, I completely disagree with BajtheJino's "one size fits all" attitude as well as the logic of "if it kills people, it should be taught."
Spins are not appropriate for every student all the time and there are many safe pilots who have never seen a spin before.
Depending on the aircraft, you might be hosed at that altitude no matter what. Hence all the emphasis on spin AVOIDANCE in training.Could I have recovered myself on my own? Maybe...probally at 3000AGL, but at 1000-700AGL in the pattern I would have killed myself.
So wait, you don't want spins to be taught, or that you shouldn't teach that low level aerobatics are dangerous, or that fuel exhaustion isn't a problem?
Maybe in other areas but they are not going to be a safe pilot if they get themselves into a spin infact they will actually be a pretty dangerous pilot while in that "phase" of flight.
Yes, training to the bare minimum is *acceptable*.
Well, yes, that's why it is the minimum standard. Is the PTS too lenient? Well, maybe, but maybe not.
Trying to teach just the PTS is absolutely obsurd...I see to many pilots that can fly to pass a checkride but throw some curveballs like your wife PMSing in the right seat, a storm rolling in, a case of get there-itious where the pilot does not go around while overshooting and then his kid spills something in the back seat while turning back he pitches up stalls spins and then panics. Game Over. You may say what is the likely hood that all those things happen but if you look back at numerous accidents pull one link out of the chain and more people would be walking the earth today.
The fuel exaustion example doesn't really work because we practice "dead sticking" it all the time in emergency landings. The low level acro is decision making where the environment and surroundings really play no factor into it. Thats like saying why don't we cut the critical engine right at the point of break on a power on stall in a twin then to recover jump out of the airplane hand crank the engine while in a tight spin then hoping back in and recovering. What does low level acro have to do with teaching private pilot's to be safe pilots?
You can take sarcastic jabs at my argument all you want, but that doesn't do much to prove why everyone must have spin training no matter what--which is basically what you originally proposed.
Sort of. The problem is that the few Chief Counsel opinions on the subject followed the FAR changes in spin instruction requirements. So, for example, there's an opinion from 1986 (when spins were not required for any certificate or rating, including the CFI) that says that parachutes =are= needed. That's been part of the problem - focusing on the "answer" rather than on the analysis.There is FAA chief consul opinion that states if a manuver required for ANY certificate or rating, then a parachute is not required. Since spins are required for the CFI, then the parachute is not required for normal spins.
I think everybody should remember that if you fly with a student past meeting PTS, it is called milking* and frowned upon.
*I can't stand that term.
Bottom line is you are correct. In an interpretation that goes back to 1977, the Chief Counsel's office give the =analysis= to be used:
Regardless of what certificate or rating the applicant is seeking, an acrobatic maneuver required for any pilot certificate or rating (even one not presently sought by the applicant) may be performed without parachutes when done by, or at the direction of, a certificated flight instructor.
That piece hasn't changed.
(btw, Mike, sorry - I guess I misunderstood your post).
So you think a private pilot should be able to perform steep turns how precisely? +/- 5 knots? 20 feet? Heck, I can't even do that unless it's smooth.Yes, the PTS is way to lenient. I think the requirements for currency are too lenient too. But, to each his own.
If your monkey can pass a checkride while exhibiting poor ADM and flight management, CRM, SRM, or whatever the heck you choose to call it, then your examiner is ignoring some very important parts of the PTS. For example...your family distraction scenario. Is there not something in the PTS about use of distractions?Negative...it is called not just teaching someone to pass a checkride. I can teach any monkey to pass a checkride according to PTS standards but ADM, CRM, and all that other good stuff takes a little while.
