I noticed that they are very "constant descent" oriented. I do like the chart on the IACs that shows the approximate altitude you should be at certain DMEs to make it a 3 degree descent. It's a nice SA tool to have to make sure you're on glidepath, ESPECIALLY on non-precision approaches.
Indeed, the Constant Angle Non-Precision Approach (CANPA) information is very useful. Be careful to notice the navaid used for the distances.
They're gonna require us to carry our own charts, too. CAs start hauling them around on 11/5 with FOs still carrying Jepps as part of the transition period. FOs will get the LIDO charts in Jan. The sample book they sent us is Jepp size, though. I've popped the pages out of the book and into my Jepp binder without any issues.
If the pages are "Jepp-sized," that removes much of the hassle. That's most definitely a change from the format we use. As I mentioned before, ours are printed on the European equivalent of "Eight and a half by eleven" paper (an ANSI standard), which is known as ISO A4. The height-to-width ratio of the International paper sizes is the square root of 2 to 1. There's a whole long story about how to get there, but the page is about 210mm x 297mm -- narrower, but longer than the paper in our printers and copiers. (Recall the ICAO-centric mentality I mentioned above? They're also ISO-centric.) We have the ability to view all charts on-line, but in order to print them on 8½" x 11" paper, we have to reduce them to keep from cutting off the ends.
On each side of an A4 page we might have 2 IAPs (2 on the opposite side for a total of 4 per sheet of paper), which most likely could be arranged to display on a "Jepp-sized" (5½" x 8½") page. However, many of the pages take up the entire page, and would have to be printed on "Jepp-sized" fold-out pages (8½" x 11") folded to the smaller size in order to be legible and usable.
Another difference is the thickness/weight of the paper. The quality of color pictures used by LIDO simply cannot be produced on the "tissue" paper used for most Jeppesen pages. This detail results in extra weight, but it tends to improve durability.
If LIDO is going to the trouble of putting their charts in a format that is compatible with Jepp binders (an ANSI standard), they're trying much harder to win the U.S. customer than Jeppesen is. Jepp's EFB product has a long way to go, and they don't seem interested in going there. Some folks in Denver ought to be getting nervous about their future.
